probably open at 650 on Monday morningMaxPain for NVDA next week is 575....
Someone might want to let the SP know
750 is higher probability than 700MaxPain for NVDA next week is 575....![]()
Will we get a discount?I believed Tivoboy mentioned this before. Only fanboy are buying the stock, everyone else is waiting for the discount.
I see a volume of 68.5M shares. Fanboys can afford like 1.5M of that volume. Even that's impressive if fanboys can collectively dump 288M dollars into Tesla over the past 4hrs.I believed Tivoboy mentioned this before. Only fanboy are buying the stock, everyone else is waiting for the discount.
The more the macro's run and they longer they run without a pullback, the harder the eventual pullback is
The more the macro's run and they longer they run with a pullback, the harder the eventual pullback is
Nope, simply because I believe there's a very cold inflation reading that's going to happen sometime in the next 1-3 months that will force a major Fed move. As in a much larger rate cut than expected.You buying puts yet TSLA/SPY/QQQ/NVDA?
For TSLA however, I'm positioning to take advantage of a pullback to 160 with a intraday dip to 146. But not doing it by buying puts.
Thanks for all your inputs, take care of yourselfalrighty, i'm done for the day
this is my last tsla trade (for now), and i am moving on to nvda/spy/spx; possibly meta but not sure yet... i hesitate to clutter this thread so i decided i'll stop volunteering info unless asked
as usual: do not be greedy - slow and steady wins the race...
ping if you need anything
i'm off to the movies!![]()
edit: last friday's gamma predicted today's approximate close (tallest wall is indeed the magnet)
Do you really expect 160?Nope, simply because I believe there's a very cold inflation reading that's going to happen sometime in the next 1-3 months that will force a major Fed move. As in a much larger rate cut than expected.
A lot the runners right now (QQQ, NVDA, MSFT, etc...) will be in valuation exploratory in a pullback so too risky to say what they pull back and for how long. For TSLA however, I'm positioning to take advantage of a pullback to 160 with a intraday dip to 146. But not doing it by buying puts.
Yes, liquidity can be a real issue, I'm always careful to pick strikes with plenty of open interest, volume and a narrow Bid/ask - if worst comes to worst you should be able to close out with a market order, in theory the MM's have to fulfil that...What have you learned this week?
Trading options is tricky. I've been using +/- gex , OI shifts, max pain, put:call ratio and delta to choose the direction I want to sell into. When the underlying is not moving, I reach for IC. Otherwise, I may sell calls but can only partake in the put side with spreads.
The past two weeks I traded SMCI and NVDA, left my TSLA DITM spreads for what appeared to be a rising SP. Next week I will either close them or roll them to 4/19 , the week after next I will be on vacation so will not have anything open that would need management.
What I learned the past two weeks as that while I nailed the sold P and C edges, it doesn't matter day of expiry when SP creeps close AND THERE IS NO LIQUIDITY. Especially with SMCI, in my case, trying to close these before market close for pennies, it's almost impossible at the ask, not a chance at midpoint. When I opened this IC, the volumes were low and bid ask difference was about .15 for each position. Choose strikes that are safe, well OTM but also those that have volume and OI. Also, don't wait until end of day Friday to close. I did because this morning it would have cost me about a 100% loss to close this same spread that now will close at $50, a profit of about 98%. I did the same with NVDA. Lot's to learn when you trade another underlying that isn't so liquid like TSLA.
NIce weekend all!
TSLA is holding steady because the market has been bullish. A bearish market could have easily seen tsla fall to 160 ….Do you really expect 160?
Agree. There are some stupid institutional traders buying in too. One trader in CNBC said, "Elon delivered a great Earnings Call and i bought in".TSLA is holding steady because the market has been bullish. A bearish market could have easily seen tsla fall to 160 ….
Perhaps this is the pullback from the more and longer they had run in the other direction. If we remove the great 2022 recession fear (that never materialized) induced periods from the chart, where would the market be from the prior trajectory?The more the macro's run and they longer they run without a pullback, the harder the eventual pullback is
