In the meantime, are you able to manually turn off Sentry Mode from the touchscreen as you exit your car in the garage and have it remain off? Obviously, not the preferred behavior, but should help with your vampire drain concern until you find a fix.
I had this same issue. The app showed me parked at a different location but I was at home. I didn’t want to change my home address as I live in a community and the Nav does take me to the right location. I solved by making the mystery address a Favorite, then I excluded favorites from Sentry Mode.
I'm have the opposite behavior. The car recognizes my home address correctly and behaves accordingly for Sentry Mode exclusion, mirror folding, HomeLink, etc. However, navigation always tells me to turn the wrong direction to enter the driveway to my house. Luckily, I know where I live.I had this same issue. The app showed me parked at a different location but I was at home. I didn’t want to change my home address as I live in a community and the Nav does take me to the right location. I solved by making the mystery address a Favorite, then I excluded favorites from Sentry Mode.
Brilliant! The address changes to my neighbor depending on which side of the garage I park my car.When your car is parked in your garage, what address does the app on your phone say is the current location? Does that match your real address? If the two are different, try setting your home address to the address that your vehicle thinks it's at when parked in your garage.
Many Thanks- This solved our issue. The mobile app address needs to match navigation home address for multiple profiles.I noticed that the addresses are tied to your profile(s). If you have multiple drivers / keys active, you may need to set the home address for all of them.
