If you want shielded cable (and this one's cheaper), here's another one:
Monoprice Cat6 Ethernet Bulk Cable - Solid, 550Mhz, STP, CM, Pure Bare Copper Wire, 23AWG, No Logo, 250ft, Blue - Monoprice.com
When grounding the shield, ground it at one end only.
If you don't know the details of the internal design of the devices, I would stick to the recommendations. Yes, RS-485 is robust and often will work with longer cables, but there are many other factors. The one I would be concerned about is the grounding. With AC power there can often be significant voltage on the neutral. The safety ground should not be used for any aspect of the electrical circuit. I would hope the RS-485 interface is optically isolated which means you don't need a common ground other than the neutral even with the full 240VAC on it. But who knows what's inside the box? Anyone have schematics?
What's wrong with the recommended 18 ga? It can't be all that expensive. But yeah, I can't see how 23 ga wouldn't be just as good for this application as long as there aren't safety issues.
The WC is a 208/240v device. There is no neutral connection, only a ground.
Ok, I still want to see the details of the design before I tell people to not listen to Tesla's recommendations. There are significant safety issues involved. A search didn't find any info.
Why would anyone want to cheap out on an 18 ga wire pair?
Because the performance might be better. Typical twisted pair 18 gauge wire uses at most a very lazy twist which doesn’t handle common mode noise rejection very well. A cat 5e, or cat 6 cable is designed for high frequency data transmission and might enable longer than 50’ distances.
I gotta say that the 50’ distance limit and the 18 gauge spec are both bizarre. RS485 normally works over hundreds of feet, and normally runs over 24 gauge wire. Sometimes 22 gauge. But 18???
Here’s a catalog link to various Belden cables that are meant for RS485. Belden Global Catalog
I thought the spec was for the distance between units. What makes you think it has anything to do with the RS-485 signal? The issue might be with the power side.
Good point. It is unclear why the limitation. Also they say the signal wire must be in a conduit, which is another bizarre requirement.
