Rhan
Thanks. Let's say you have 150 miles of range at 50%. If you battery lost 10% would you still have 150 miles at 10% or would just loose max range (if that makes sense.)You will always be able to charge to 100% but each percent will be less worth.
The range indication by the battery symbol that you can use instead of % will drop.
For a 3 LR it might start at for example 358miles. (Just grabbing a number as I do not se your cars spec).
When you have lost ~2% battery capacity the range will start to decrease for a full charge. After loosing 12% battery capacity , you will have lost 10% of the range (as the forat 2% are hidden from displayed range loss).
In this case you still have 100% on a full charge but each percent give you 12% less range.
