Yggdrasill
It doesn't surprise me that they are very similar, if not identical, but the S85 will pull less amps than the P85D. As you were eager to point out, the waste heat is based on the square of the current, so you won't need to back off the amps very much to make a big difference. Maybe a possible bad connection or FOD would be detected in a P85D, but the S85 simply doesn't stress the HVJB as much as a supercharger, and not in the same way, so there's definitely a potential for there to have been a fault there.I've actually concluded that the inverters are pretty much identical, component wise. Software limits the current allowed by the various models. There might be some binning happening with the performance vs non-performance versions, but physically they're the same. One day I may fully test this by forcing an S85 to accept P85 firmware, but that's a tale for another day.
I couldn't "pin this fire on Tesla" even if I wanted to. But as a TSLA investor I am interested to find out the cause of the fire and the potential impact to TSLA.We'll have to just agree to disagree on the significance of heat build up in various components I guess, which is unfortunate since my data is based on the actual components and real data, and your assertions are based on.......... trying to pin this fire on Tesla.
My current assessment is this: Very possibly the cause of the fire is not a fault of Tesla hardware, but in the event that it is fault in the HVJB or something similar, the impact will be minimal. If so, we're likely talking about a production or servicing fault, not a design fault, and we could possibly be talking about a $1000 inspection on maybe as many as 50k cars, but most likely the impact will be less than that. The superchargers are unlikely to be to be at fault.
I certainly respect you and the data you have collected, but you've supplied no data that contradicts anything I've said.
