Details :-
To Strip Vehicle And Renew
L/Upp Inn Hinge Pillar (Comp Work)
L/A-Pillar
Left Door Sill Panel
Partial Left Centre Sill Panel
Left B-Pillar
Carry Out Scan "Toolbox"
Bleed Radiator System
Remove And Refit/Renew (Check New Parts List)
Front Bumper
Lower Engine Protection
Left Front Wing
Windscreen
Glass Sunroof
Headlining
L/F Door Trim
L/F Inner Channel Seal
L/F Outer Window Channel Moulding
Left Front Door Window
Left Mirror
L/F Door Foil
Left Front Outer Door Handle
Left Front Door Speaker
L/Door Sill Protector
Mount L/LWR Hinge Pillar Parts
L/Lower B-Pillar Trim
Left Upper B-Pillar Trim
L/R Sill Trim
R/Door Sill Protector
R/Lower A-Pillar Trim
R/Lower B-Pillar Trim
Right Upper B-Pillar Tri
R/R Sill Trim
Rear Screen
L/Upp A-Pillar L/B-Pillar Detach + Refit
L/Upp A-Pillar L/Sill Detach + Refit
Rear Engine Guard
Instrument Panel Attached Parts
Instrument Panel
R/F Seat
Left Rear Outer Seat Armrest
Right Rear Outer Seat Armrest
Rear Seat Cushion
Floor Bracket Detach + Refit
High-Voltage Battery
Left Front Wheel Full Bodyside LH 1073673-S0-B
Rivet, 4.8 MM X20 Rivet 4.8Mmshort X10
Flowformrivets08 X10 Renew Flowformrivets18 X20
Bolt X2 Renew Rivnut,M6X1,4.0MM X1 Renew
Plug Round 25MM 1077461-00-A.
Seam Sealer Renew
Check Decommision Vehicle
Check And Quality Control
Check And Road Test
Check Water Test
Repair
Left Front Door
Prepare And Paint
Preparation For Pre-Painting
Left B-Pillar New Part Painting
Left A-Pillar New Part Painting
Left Front Door Repair Painting <50%
Rebuild Vehicle Fitting New Parts Listed
Labour Value £4043.00
Paint and Materials £375.61
Specialist/Other Charges £232.65
Pre Diag Check Specialist 75.00
Estimate 37005, Page 2
Post Diag Check Specialist 75.00
E.P.A. Charge Specialist 15.00
Cutting Discs Specialist 49.65
Sound Pad Specialist 8.00
Covid19 Clean Specialist 10.00
New Parts :- £1138.17
Windscreen Bond Kit 11.67
Windscreen Primer 9.17
L/F Upper Door Hinge 41.67
L/F Lower Door Hinge 41.67
Left B-Pillar 0.00
Left A-Pillar 0.00
L/Sill Protection 191.67
Full Bodyside LH 725.00
Rivet, 4.8 MM X20 20.00
Rivet 4.8Mmshort X10 10.00
Flowformrivets08 X10 10.00
Flowformrivets18 X20 20.00
Bolt X2 10.00
Rivnut,M6X1,4.0MM X1 5.00
Plug Round 25MM 10.00
Seam Sealer 10.00
Sundries 22.32
End of New Parts
_______
Sub-Total £5789.43
VAT £1157.86
_______
Estimate Total £6947.29
