Tesla doesn’t decide the rated range, it’s the result of the EPA test cycle. It’s a matter of YMMV, just as with ICE cars. Drive the EPA test cycle and by definition you would get the rated range in your car.Sadly, Tesla's marketing claims are best case scenario, which is similar to most other companies, but I wish Tesla would be a little more conservative in their claims. I basically never get rated range on my Tesla, and charge times are indeed lengthier than marketing would suggest.
Tesloop charges to 100% then immediately uses the charge. The "dont charge to 100" is the normal overnight owners, whose cars will sit and drain slowly for a few hours before driven.Tesloop charges to 100% on a daily basis. Many people do. While it does cause a little degradation it's completely irrelevant to the issue he has. His charge time is almost twice of what it should be and the car should charge to 100% every time you need to or want to.
I don't know if I'm going to need hip waders for this thread, but here's an answer to the OP's repeated question, "How can I take long trips with a car that takes 2 hours to charge to 100%?!"
Short answer:
Travel more. Your battery is fine enough as is.
Better answer:
I average MAYBE 10% slower travel than in an ICE but that takes into account that I rarely speed anymore. I define speeding as in excess of 10mph over the posted limit, so your mileage may vary.
More for the OP: A good rule of thumb for a day of travel is to maintain at or in excess of 50mph gross time. So. If you want to travel 750 miles per day, as a friend of mine and I did recently from Vermont to California, in order to get there in 4 days (we opted to overnight in Vegas but could have easily gotten to LA that day if we wanted), then figure 15 hours of *travel* per day.
Note I did not say 15 hours of *driving*. Travel being defined as time between leaving the hotel and checking into the next one - including charging stops and meals and such.
Here's how that works - you rarely, and I mean rarely, in an S85 or larger capacity car, need to charge to 100%. After awhile, you'll be fine arriving at the next SC with 2%, 3% or 5%, but as a rule of thumb, it's a good idea to arrive with 15%-20%, let's say. MOST of your legs to the next SC can be accomplished by charging to 80% or less. There are exceptions, but there are fewer every year as more SCs are added. If you're traveling unfamiliar ground, then charge until you have a buffer of 20% to the next SC. If there's wind and/or elevation, then consider 30% but this is rarely necessary.
EV Trip Planner and the available .csv files for trips therein, along with the usual other tools will go a long way toward reducing range anxiety.
Whatever you do, do NOT charge to 100% at every SC when you don't need it. People like me will leave "Don't be an ICEhole" cards on your car and glower ominously in your general direction. Or point and laugh - it depends upon the day.
As an experimant, try lowering the amps (say 30, like a L2), see if the slower charge does better... (at home)
Please explain to me why you continually want to charge to 100%, that alone does more damage to your battery than anything else. Sounds like a self inflicted wound. I suggest you read your owner's manual and hire a better attorney.
