Ive been testing mine recently, at 40 degree outside temp, the register vent temps were inside-temp + ~20 degrees. Example: I like my home around 72, came home to 66 degrees (Nest "away" feature dropped the temp). Registers showed a range of mid 80s at the start and mid 90s near the tail end of the heating cycle.Thanks. We already have a relatively new (5 years old) high-efficiency heater that has multiple stage outputs. But if we need to replace this in the future I will consider a heat pump.
I hope they blow warm air these days. My previous homes that had heat pumps blew air that was about the same temperature as the setting, and I did not like this.
When temps were in the mid teens, I relied heavily on the LP furnace to overcome the same low drops (much faster), but then switched to the heat pump to maintain.
I actually ran out of propane this last week as I'd just bought the place in October and the 250 gallon tank was only about 20~30% full. Heat pump has been keeping the house right at 72 without any issues. Outside temp ranging from low 30s to 50s. Throughout the week.
Further research I've discovered the Nest "smart" features are competing with the Bosch Bova 2.0 heat pump "learning" stuff... I've since turned off all the Nest features and might be getting the Bosch BCC100 thermostat instead.
There are lots of dipswitch feautures on the heatpump as well to increase on demand heating capability and mulitple stages, but I believe my installer configured it to use the Furnace for high demand and below 40 degrees for efficiencies.
