I'm curious. How are solar roofs wired? I imagine that the tiles are connected in series to form multiple strings? If so, does partial shading kill the string production?
Does anyone know?
You can watch YouTube videos of installations. Here’s one that shows linking the wires at 2:50:
Mine was very similar, I have a super string with two 35 tile strings in parallel as PV1, then two smaller 24 tile strings for PV2/ PV3 on a 3 string system.
The voltage should be higher on a cloudy day since voltage is proportional to temperature so you're gonna have higher voltage on a cool cloudy day than a hot sunny one.
parallel strings . . .if one string gets shaded production of the unshaded panels goes down.
Shouldn't be toooo bad.... unless one string gets shade and the other doesn't. The current through each string can vary but the voltages should be the ~same. Voltage changes with temperature and current with sunlight. So there will be a slight mismatch since the one in more sun would also be a little warmer but I don't think it would be significant.@nwdiver 's comment about shading has me wondering about my PV2 strings which are split - one east and one south.
Is that right?
Cheers, Wayne
6.8kW total.How many kW? Was this before the Tesla inverters? It's a little surprising they did parallel strings. If there's no shade I guess that should be ok but if one string gets shaded production of the unshaded panels goes down. I have an old SMA inverter with 3 parallel strings since it only has 1 MPPT tracker. In the evening 3 panels get shaded in a 14 panel string. Basically kills the other 11 panels even though they're still in ~full sun. Happens around 5pm only in the summer so I'm not losing that much production.
Interesting that they run in parallel, I guess they have to do that to stay under max input voltage?My solar roof is a 9.94 kW system with 3 paired/parallel? strings connected to a Delta M8 inverter.
The PV1 pair has: 36 south roof tiles + 36 south roof tiles.
The PV2 pair has: 28 south roof tiles+ 28 east roof tiles.
The PV3 pair has: 21 west roof tiles + 21 west roof tiles.
Here are production values for a recent day that I pulled from the M Professional app:
I think the little bump up after 4pm is when my south facing roof is shaded but my west facing roof gets a small burst sunshine that sneaks by my neighbor's house as the sun sets. @nwdiver 's comment about shading has me wondering about my PV2 strings which are split - one east and one south.
6.8kW total.
I didn't realize shade on one parallel string messed up the other. How much of an impact is it? Just an efficiency decrease or a total reduction?
There is a lot of shade on my lower roof.Depends on the situation but it can be somewhat dramatic. I think worst case is if only one string is partially in shade to the extent that the unshaded portion is unable to achieve sufficient voltage to allow any current flow. Basically if 30% of one string is in shade the other ~70% that's unshaded could stop producing if the parallel string is also unshaded. Voltage in parallel strings needs to be ~equal. But if there's no shade you should be fine.
I have total shade on my west panels from my garage until like noon. Just the way it is for meThere is a lot of shade on my lower roof.
I've been seeing things like this where production jumps up at 8 and 2, with dips at 9 and 1, due to shade on the lower roof from my chimney in the AM, and the upper roof in the PM.
That's what I was afraid of.Certainly looks like that's what's happening. The entire string is starting and stopping production. I get a similar effect around 5 in the evening in the summer.
You mentioned having 3 strings. What kind of inverter do you have?
I have a delta M8, 3 strings, I think they probably should have wired up my 2x23 tile strings in parallel to 1x MPPT, they are both on the garage roof very close to each other with no shading issues. Then the lower roof 35 tiles could be on its own MPPT, and the top roof 35 tiles wouldn't be affected by the shading...
My strings run down to boxes in the attic and from there down to the inverters.Does sound like that would have been better. Wonder where the strings are joined. If it's on the roof that would be a PITA to rewire but they might have run them separately into the inverters combiner box. If that's the case it might only take ~20 minutes to fix.
It's not so much that the string in shade is effecting the unshaded string. Essentially 2 different power points are being created since one string is effectively shorter than the other if one is in shade. So there's a 'M'PP at ~300v and one and ~400v. The inverter has to determine which one yields more power. At the higher voltage the unshaded string is basically producing at it's MPP and the shaded string is at ~0. At the lower voltage it's compromising and neither string is happy but overall power could be higher than the one unshaded string alone. Either way.... unshaded panels are losing power because of shaded panels... which is why parallel strings suck.
