Skimpy meaning 2.6 KWh (Suniva panels). I've since added a heat pump and tankless electric water heater (ditching a gas furnace and water heater in the process), so I have expansion on the mind (to say nothing of the energy demands that an eventual EV will require). To take advantage of a Powerwall battery backup, the parallel microinverter configuration I have with Enphase would have to be dumped and the single SolarEdge inverter would take its place. This loss of redundancy takes away one of the key benefits of this system, it seems (one panel failure not disrupting the output of the remainder), not that I've had occasion to use this feature since installation 2 years ago, but from what I understand this multiple inverter configuration also maximizes output so I'm not sure I'd want to get rid of it. There must be a more elegant way to add battery backup (something along the lines of your LifePo pack), but I take it requires incorporating what you described as a hybrid inverter between the solar array's microinverter and battery, and the product SolarEdge is introducing here is no such beast. I'm in no rush to add battery backup, but it's been at the back of mind as something to add in the future. Much research to do, but the next thing I'm likely to do is add generation capacity. Thanks for the exposition.
