Yes our first attempt at breaking out failed after macros became a drag, actually starting the day after I mentioned hedging for macros. Good news is that so far we have not broken any key supports. The 345 I came up with was based on both the tenkan(blue line) on the weekly and kijun(red line) on the daily both lining up there. Since then the weekly tenkan dropped to 338 and the daily kijun dropped to 340, and we've held above those levels.
View attachment 247071 View attachment 247072
What's even more important is keeping above the daily cloud itself, and the weekly bollinger mid. As long as we continue to hold above those areas, a failed breakout can turn into consolidation and a second attempt. Also, the reason why holding above those areas is important is that it means we are still in an uptrend, which is why I would want to be leveraged up to begin with. When you are in a defined uptrend you want to lever up. When you are uncertain you want to be unlevered. And when you are in a defined downtrend you want to be hedged or short. Sounds simple but really that's all there is to the game. Hard part is defining trends, and doing so swiftly when trends first begin to change, and those cloud indicators are part of what helps me do that.
