SpaceX F9 - Starlink V1.0-16 - LC-39A
Grendal
SpaceX Moderator
Moderator
Jan 31, 2012
7,848
12,094
Santa Fe, New Mexico
Launch Date: January 20
Launch Window: 8:02 AM EST, 5:02 AM PST (1302 UTC)
Launch site: LC-39A, Kennedy Space Center, Florida
Core Booster Recovery: ASDS - JRTI
Booster: B1051-8
Fairings: TBD
Mass: 60 satellites at 260 kg each - 15,600 kg (34,500 lbs)
Orbit: LEO
A SpaceX Falcon 9 rocket will launch the 17th batch of approximately 60 satellites for SpaceX’s Starlink broadband network, a mission designated Starlink V1.0-L16.
Reactions: e-FTW
70% chance for early tomorrow. 90% with a 24 hour delay.
Reactions: scaesare
"additional pre-launch inspections". Huh. I wonder what that could be since they've already been delayed?
That's usually code for "someone forgot to check off that line in that procedure", where an otherwise self-evident non-issue necessitates a re-run (to some degree or another) of the procedure/process/whatever for completeness.
Could also be a flag for a lower level anomaly (whatever terminology they use) where its likely going to be UAI but with the slimmest chance of being a bigger deal.
If it were a verified anomaly, or something like a gator stuck somewhere unfortunate, we'd hear about it.
Was that a satellite that came tumbling across the view of the camera?
I tried playing back at 1/4 speed but it's not clear.
Bird? :eek:
Definitely some kind of debris, hard to tell where it actually came from. Maybe a small burst from a thruster or a blow-off valve of some sort dislodged A Thing? Maybe whatever causes that thermal blanket pulsating? (In the previous camera angle you can see one puff of the blanket)
Other than that, near as I can tell anyway, there's no momentum being added to the stack that would cause displaced debris to actually move relative to the stack.
There's also some pixels flashing by a few seconds before. That they're going slow enough to see implies they're from the stack, but they also seem to be coming from and moving in a really weird direction.
Reactions: Grendal
