Conversationally (not adversarially)
Always!
Sure, however there is some good mass manufacturing expertise available to SpaceX.
Sort of. They have low volume space production on lock with their booster production, and certainly some good stuff in their engine production line that has slightly higher volume. The issue is that what they're shooting for is truly unprecedented volume in the space industry, and that's all the way down the supply chain, not just at system level. They need 35,000 torque rods and most likely 45,000 reaction wheels. The entire space industry [including cubesats] probably hasn't made that many of those items in the past decade, if not longer, and you'd be hard pressed to find any aerospace supplier providing higher function gizmos at that volume, and certainly not at Starlink's required rate. And...because most of what's out there hasn't been designed to be built at such massive volumes, its really hard to just say "we'll invest in Industry 4.0 and build what you need"...you almost need to white page everything.
The new 5 year orbital life and zero parts surviving re-entry may be part of a super low cost satellite platform (space bamboo?)
Yeah, especially the 5 year mission life (the burn-up thing is a bit oversold--a lot of smaller spacecraft completely burn up, and re-entry analysis is a required thing for everyone). Anyway, 5 years in LEO (maybe 6) is right about where the reliability curve knees up into really needing class S parts; keeping the planned mission life short makes it easier to use significantly cheaper COTS parts and still manage radiation degradation. The hard part is finding the balance: First order, if you're dropping from 7 years to 5 years so you can use cheaper parts, that means your cost reduction has to be at least 30% to make up for the 'lost' revenue.
There are use cases that work with intermittent connection (remote sensing for instance), depending on bandwidth, they could also burst download data to sites.
For sure, its not like there's going to be a useless constellation up there waiting to get turned on. its just that those early adopters aren't going to be the ones that pay for the rest of the buildout. For instance, by the time the constellation is turned on that reaction wheel supplier (whether internal to SpaceX or external) will have
long committed capex to industrializing production to build those tens of thousands of wheels.
In reality, those early adopters are mostly going to be there to demonstrate the capability of the growing constellation, probably on the back of a pretty sweetheart deal. Then as more anchor customers sign on for service more funds will be released to keep the production machine running.
