SomeJoe7777
Marginally-Known Member
I put together a D-compatible tire repair solution for myself last weekend. The following components all fit in the D-frunk and should be able to let you repair most tire problems on your own:
Total: $201.64 + tax & shipping.
You can take any tire off the car (remember to put air suspension in jack mode) to repair it with the BlackJack kit or the Tesla kit, air it back up after repair with the Tesla kit, and put the tire back on the car.
I considered just the two tire repair kits, but I was concerned that I might not be able to repair the tire while it was on the car. Especially in the case of a puncture to one of the rear tires towards the centerline of the car, this would be very difficult to reach with the BlackJack tools.
- BlackJack KT-340 Tire Repair Kit - $51.71 - Contains the tools and patches necessary to fix any non-sidewall puncture.
- Tesla Tire Repair Kit - $50.00 - Air compressor and sealant (if required).
- 2-Ton Compact Hydraulic Floor Jack - $29.99 - Not the best floor jack in the world, but good enough for emergency use, will lift the Tesla, and fits easily in the frunk.
- 1/2" Drive 21mm Deep Wall Socket - $3.99 - Fits lug nuts on OEM 19" and 21" wheels. Also works with the Tesla locking lug nuts.
- 1/2" Drive Click-Type Torque Wrench - $21.99 - Used to torque lug nuts to 129 ft-lbs.
- 1/2" Drive 18" Ratcheting Breaker Bar - $21.99 - Removes lug nuts fairly easily, ratcheting mechanism seems fairly solid.
- Solid Rubber Wheel Chock - $7.99 x2 - Chock the wheels opposite to the tire you're removing.
- Mechanics Gloves - $5.99
