Tar/Sap spot that i cant seem to remove. Pictures included
washed my car today and noticed this tar/sap/hard water spot that i cant seem to remove at all
ive tried chemical guys hard water remover, rubbing alcohol and clay bar already
any idea what this could be and what i can use to get this off?
THANK YOU!
While you took good pictures and the spot is clearly visible, it is hard to tell from the picture. with the steps you have already taken, looking at it, again, hard to tell from the pictures, it seems like it may be an actual issue with the clear coat. If you gently rub your finger over it, do you feel anything?
seems like it was bird poop etched into the coat. searched around and i found the hair dryer method used by some ppl. got rid of.....85 percent of by just heating up that spot. not really visible under white light now...unless i really look for it.
link to the method used by this youtuber if anyone else find themselves with this problem
thanks for all the comments!
