I can't speak for TyH2009 and I have not done a direct comparison like he did. But I have used both products. I think TW Seal and Shine and the TC CDS are both very durable and offer a lot of protection. Honestly either one is a great product. I personally prefer the TC CDS because it has a slicker feel when applying it and I think a bit more gloss than the TW. And I also prefer the scent of the TC CDS. But again it is really a personal preference and the TW Seal and Shine is a great product and esp a great value.
I've seen some of the you tube detailers dilute TC CDS 1:1 which would make it much cheaper than S&S. Any experience doing this and its effect on performance?
Also, do you reuse your microfiber towels used for TC CDS, or any ceramic spray for that matter? I read mixed opinions on reusing them due to the ceramic hardening within the microfiber and potentially causing scratching.
It sounds like they are pretty comparable and basically a toss up. I think think I'll stick with S&S just so I don't have to worry about my microfibers. Any suggestions on how to bump up the gloss when using S&S? I have Meguiars D156 and Optimum Spray wax.
So can both TW S&S and TC CDS be layered? On each other? Can they be used after every car wash?
Looking at TyH2009's pictures, to me it seems like TW Seal and Shine held up better than TC CDS after washing the car. Thoughts?
It's kinda hard to say, this winter hasn't been great and I haven't washed that car in a while, haven't been driving it much, since I don't really drive it in the rain/snow/wet roads/etc, but I would say they're pretty close. I will admit that I didn't care much for how the TW S&S smelled, the TC was more pleasant, and the TC was much easier to apply/remove than the TW S&S.I can't speak for TyH2009 and I have not done a direct comparison like he did. But I have used both products. I think TW Seal and Shine and the TC CDS are both very durable and offer a lot of protection. Honestly either one is a great product. I personally prefer the TC CDS because it has a slicker feel when applying it and I think a bit more gloss than the TW. And I also prefer the scent of the TC CDS. But again it is really a personal preference and the TW Seal and Shine is a great product and esp a great value.
Once I get a chance to wash the car again, I'll compare and do a follow up.
Joebruin77, May I ask why you have switched from TC CDS to The Last Coat 2.0?
I’m currently using Bead Maker as a topper over my professionally applied Kamikaze ISM ceramic coating. As you know, BM has insane slickness & gloss, but is not very durable. For me, it probably lasts only about 1 month before the slickness & gloss drops to a point where I want to apply another coat. To be fair, I like to keep my paint surface super slick all the time, so I use BM as a drying agent at least every 3 or 4 ONR washes, and I probably do an ONR wash at least once a week.
I think The Last Coat 2.0 is quite a bit more expensive than BM (which is not really a concern for me). I’m trying to figure out if TLC 2.0 is durable & keeps its gloss/slickness long enough where I feel I don’t need to apply it but perhaps every 3 or 4 months.
Wow, thanks for the reply and all the great information!
After using Bead Maker on my ceramic coated vehicle for the past several months, I can say with absolute confidence that it does not degrade the hydrophobic properties of the particular ceramic coating that I have (Kamikaze ISM). My observation is that BM does actually give the ceramic coating a boost in gloss & slickness without negatively affecting the other desired characteristics of ceramic coating (namely hydrophobic properties). I have not experienced any of the degradation that the reviewer demonstrated/observed in his video. I’m sure you’ll agree that real world experience trumps any controlled experiment done on a test panel.
Perhaps there are some ceramic coatings that do not play nice with the polymers in Bead Maker. However, the chemist/developer of BM claims it is compatible with all ceramic coatings. I can’t speak for the other brands of ceramic coatings on the market. But when applied on top of Kamikaze ISM, BM has been/done everything they claim... add insane gloss & slickness. I just wish that crazy gloss & slickness would last 3-4 months instead of just 1-2.
Kamikaze does make (& I have used) a ceramic maintenance booster called Overcoat, which helps maintain/boost the hydrophobic properties of the original/base ceramic coating. However, it cannot match the (temporary) gloss & slickness that I get when I apply BM on top of my ceramic coating.
So, I’m looking for an easy-to-apply detail spray that will give me comparable gloss & slickness of BM, but lasts a little longer...
I’m glad to hear BM works well with your particular ceramic coating. I also have a good understanding of your needs.
Here are some products to consider:
TC CDS is definitely something you should try. As discussed above, it does remind me of BM in terms of its ease of use and slickness. But it is much more durable and provides better protection than BM.
Opticoat (Optimum’s professional line) makes a ceramic infused spray sealant I love called Hyper Seal. I did notice enhanced gloss after applying it. It is pricey ($39) but you only need to use a little at a time.
The Last Coat 2.0 and their topper Amp is a great combo. Both are ceramic infused. The Last Coat 2.0 sealant offers very durable protection. Amp is not designed for long term protection but rather focused more on pumping up the gloss and slickness for about a month. The two are chemically compatible and work well together since they are made by the same manufacturer.
Finally, there is a whole new category of products coming on the market that contain graphene. IGL makes a graphene liquid. In one review I saw, the graphene product achieved the highest gloss readings I have ever seen. However, I do not know if you can apply graphene on top of a ceramic coating or if you should only use it directly on paint. You could contact IGL and ask them.
Hope that helps!
Just a fyi. For those in NJ, Technicians Choice Ceramic Detail Spray 1 gal is $29 at PAL Automotive Specialties in Piscataway.
Not the greatest video, but let me know what you think. Both seem to be holding up very well. Again keep in mind I don’t really drive this car in the rain, snow, etc the car was mostly dusty/dirty from road grime and salt dust.
