Someone did a comparison of these to stock on Youtube.im interested on how these ride
I've been looking at these vs the MPP comfort (non adjustable)Someone did a comparison of these to stock on Youtube.
My shop will isntalling these on a RWD. Will report back next week.
Link to Tein:
That isn't a solid mount. It has more rubber to reduce NVH than the OE mount.I've been looking at these vs the MPP comfort (non adjustable)
My immediate gripe about them is they don't reuse the hat, so they are likely going to be noisier.
When you do the drive could you take note of the ride quality as well as the noise, vibration, rattles ect?
I hope to see your upcoming review of these.
I did watch this review, they seemed pretty promising based on what was said. Compared to MPP (comfort non-adjust) in a similar price bracket they have a few advantages, they are adjustable. I read conflicting info about reusing the hat, people mostly said it would be noisier, but it also makes the install easier.That isn't a solid mount. It has more rubber to reduce NVH than the OE mount.
Here is a good review:
Will report back soon.I did watch this review, they seemed pretty promising based on what was said. Compared to MPP (comfort non-adjust) in a similar price bracket they have a few advantages, they are adjustable. I read conflicting info about reusing the hat, people mostly said it would be noisier, but it also makes the install easier.
I find that people on this forum are pretty honest with their takes on aftermarket parts, thats why I wanted to wait and see how this install turned out for your customer. Basically if its good, i'll go with these, if not i'll go with MPP. I don't really want to move up to the 2500 MPP comfort adjust price bracket if I can avoid it. If these are say 80% as good at 50% the cost it would be a reasonable choice.
Full and more rubber than OE on the Tein shock mounts(both front and rear). These are definitely designed with ride quality in mind, the opposit of a pillowball mount or spherical bearing mount.What kind of bushing/bearing setup are they using? Any idea yet how it compares to stock rubber and also to all-metal pillowballs? (Those being opposite ends of the spectrum I guess.)
You are welcome. Happy to post something that has not been installed or reviewed.Progressive rate springs! That's also a focus on ride quality over handling, right?
Thanks for the pics and driving impressions.![]()
These are surprising well made and damping seems to be decent for the price. I do recommend these.Thanks for the review. I am leaning towards these since I can also do sway bars for the price. Hard to beat a set of these and sway bars or non adjustable coil overs for roughly the same money.
If it were your money, these and sway bars or MPP comfort NON adjustable coil overs. (I also have a RWD m3)
Thanks, ordered these. Fingers crossed, I've had good luck so far with getting less expensive parts and getting close to the same results. My wheels are forged from china, jova wheels, and those have been great at about 1/5 the cost of forged wheels from canada or usa. It's hard to justify some of the prices for a standard range and someone who does not track their car and just wants it to be moderately better.These are surprising well made and damping seems to be decent for the price. I do recommend these.
Keep in mind that with a bigger anti roll bar you will need to turn up the damping since in a turn the bar adds to the spring rate.
Yes, you can. See the two rubber plugs on the rear shock mounts? Remove one or the other and the opening is large enough to insert your finger to adjust. Front is just under the frunk cover. Alternatively, you can drill a 2-3 mm hole and use the supplied Tein adjusting tool.Thanks, ordered these. Fingers crossed, I've had good luck so far with getting less expensive parts and getting close to the same results. My wheels are forged from china, jova wheels, and those have been great at about 1/5 the cost of forged wheels from canada or usa. It's hard to justify some of the prices for a standard range and someone who does not track their car and just wants it to be moderately better.
Can you get to the adjustments without pulling the wheel?
That is available but out of stock right. Call Tein for ETA.Too bad there is no availability for the AWD set
Let us know how you like them. Might be interested in these as wellThanks, ordered these. Fingers crossed, I've had good luck so far with getting less expensive parts and getting close to the same results. My wheels are forged from china, jova wheels, and those have been great at about 1/5 the cost of forged wheels from canada or usa. It's hard to justify some of the prices for a standard range and someone who does not track their car and just wants it to be moderately better.
I'll put up a thread, don't hold your breath though. Shipping in canada is a joke then I need to install them. The only thing the commie canada post can figure out is how to cost more money while lowering performance.Let us know how you like them. Might be interested in these as well
