[email protected]
- Mar 30, 2010
- 461
- 2,576
I think that the real limit on regen isn't the tire traction, it's the rate at which the battery can accept charge. This doesn't seem to be anywhere near the limit of the tires. Recall that as far as the tires are concerned, speeding up and slowing down at the same rate and initial speed requires applying the same amount of power (ignoring air drag), and the regen power is way lower than the accel power.
Of course it is. You have to account two times the internal losses of motor and PEM.
Also, I disagree with the statement that "The amount of kinetic energy that is regen-able is a lot higher for FWD or AWD than RWD." I think you're confusing power (rate of energy recapture) and energy (total watt hours put back into the battery) here.
No I'm not. I was talking about kinetic energy. The word power is nowhere to be found. The harder you "brake" the more weight gets distributed to the front wheels, the more energy you could possibly regen on the front wheels and the less on the rear wheels. Quite clear to me.
If the limit really was the tires rather than the battery, then you'd be able to put it in faster with RWD, but it for a shorter amount of time (because you'd be stopped).
Someone mentioned a 0.2g (deceleration) rate for regen for the roadster. That isn't much and nowhere near the maxium of around 0.9g on the brakes possible for a street car. During full accel they suck out north of 200 kw to feed the 185 kW motor accounting the losses. That is a about 4C discharge. I have a hard time to believe that at least a 2C charge (~ 100 kw) is not be possible if tire traction and the regen circuits wouldn't limit it. The former is a conceptual thing, the latter a cost thing.
TM puts a 45 minutes charge from zero to full into the Model S specs. Assuming this is for the small 42kWh battery, that would make it a 56 kW charge. Certainly more than the 40 kW that's on the kW gauge for the roadster for regen.
