Webeevdrivers
This is what you can expect.Yes! That is exactly what happened. I was charging at 0 to 1 mph! Good point. When the 30TT is back in stock, I will get one. Would tbT be 2 mph though? Here is what we were getting at 12A.
Beware though. You can see in my pic that the voltage is 109 volts. If it stays like that for long it will assume there is a problem and drop the current to 18 amps. Or even 12 amps if the voltage drops too much. Don’t worry, the car will send you a message that it is reducing current until the voltage climbs back up. It doesn’t happen much. It mostly happens in old campgrounds with crappy infrastructure.
Hope that helps.
