Vendor Tesla Brakes – Model S, 3, X, Y Brake Calipers, Pads, and Rotors
MountainPass
Global Vendor
Mar 2, 2018
2,171
4,588
Toronto, Canada
Listings
Tesla Model 3 Base Front Brakes
Determining the combination of brake calipers, pads, and rotors on your Tesla can be pretty confusing – especially with Tesla making updates on a seemingly random timeline.
In this article, we hope to answer any questions you might have with regard to which specific braking components are equipped on your Model S, 3, X, or Y, which will help you ensure you order the right brake pads or rotors for your vehicle when it is time to change them! Please don’t hesitate to email us if you have any questions.
Tesla Model 3 Brake Calipers:​
There are two variants of the braking system on the Model 3 – Base and Performance. This has been unchanged since the start of production of the Model 3. Both rear calipers have an integrated parking brake, and both front calipers are fixed with four pistons.
AxleCaliper DescriptionBrake PadBrake RotorRotor WeightCaliper StyleApplication
FrontBrembo Base (Silver)3/Y Base320 x 25 mm One-Piece21.0 lbsFixed 4-PistonModel 3 SR, SR+, LR, LR AWD, Performance (Non-PUP)
RearMando Base (Silver)3/Y Base335 x 20 mm One-Piece16.9 lbsFloating 1-PistonModel 3 SR, SR+, LR, LR AWD, Performance (Non-PUP)
FrontBrembo Performance (Red)3/Y Performance355 x 25 mm Two-Piece19.2 lbsFixed 4-PistonModel 3 Performance (With PUP)
RearBrembo Performance (Red)3/Y Performance335 x 20 mm Two-Piece14.2 lbsFloating 1-PistonModel 3 Performance (With PUP)
As you can see in the chart, the notable differences are in the size of the front rotor, the design of the rotors (two-piece versus one-piece), and the aesthetic properties of the calipers (Red vs Silver). It is interesting to note that despite looking like a fixed caliper, the rear caliper on the Performance is simply a floating single-piston design with a fancy-looking outer clamshell!
Interestingly, it was possible to order a Model 3 Performance in 2018/2019 without the Performance Upgrade Package (PUP); these cars came with the Base (Silver) brakes, and are referred to as “Stealth” Model 3’s in the community.
Tesla Model 3 at Laguna Seca garages
Tesla Model Y Brake Calipers:​
The Model Y is more complicated, there is a fair bit of crossover from the Model 3, but the configuration has also changed in the rear since the start of production.
FrontBrembo Performance (Silver)3/Y Performance355 x 25 mm One-Piece23.4 lbsFixed 4-PistonModel Y SR, LR AWD
RearMando Base (Silver)3/Y Base335 x 20 mm One-Piece17.2 lbsFloating 1-PistonModel Y SR, LR AWD
FrontBrembo Performance (Red)3/Y Performance355 x 25 mm One-Piece23.4 lbsFixed 4-PistonModel Y Performance
RearBrembo Performance (Red)3/Y Performance335 x 20 mm One-Piece17.2 lbsFloating 1-PistonModel Y Performance (up to 8/15/2022)
RearMando Base (Red)3/Y Base335 x 20 mm One-Piece17.2 lbsFloating 1-PistonModel Y Performance (post 8/15/2022)
The main difference is that there is no carryover for the rotors – they are all a one-piece design specific to Model Y. However, our MPP Model 3 two-piece rotor solutions are compatible with the Model Y. As you can see, Tesla uses the same brakes on the front axle – the only difference being the Performance comes with a nice Red powder-coating finish and the base does not.
The rear is a bit more complex. Up until recently, the Model Y Performance used the same rear Caliper as the Model 3 Performance. However, a change was made in August of 2022 – now the Performance Model Y uses the same base rear caliper as the AWD/SR Model Y and base Model 3, – with a Red cover over it – talk about cost savings! We sure don’t like caliper covers and it is disappointing to see Tesla resorting to that.
As with the Model 3, there was a brief period of early 2020 Model Y builds that could be configured as a Performance without the Performance braking system.
Tesla Model S/X Palladium Brake Systems:​
Tesla does not offer multiple caliper options on the Model S and X. Both the Plaid and Long Range are equipped with the same brakes. The only exception is that the Model X is fitted with larger front rotors, utilizing different caliper placement on the upright. In addition, the rear brakes are a carryover from the 2018 change, when Tesla switched from a fixed caliper in the rear to a floating slider with an integrated parking brake.
FrontBrembo (Black)Palladium Base380 x 32mm One-Piece27.8 lbsFixed 4-PistonPalladium Model S Long Range, Plaid
FrontBrembo (Black)Palladium Base395 x 32 One-Piece27.8 lbsFixed 4-PistonPalladium Model X Long Range, Plaid
RearMando (Black)Palladium Base365 x 28mm One-Piece20.5 lbsFloating 1-Piston2017+ Model S/X Long Range, Plaid
As you will notice, the rotors on the Long Range & Plaid Model S & X are quite a bit larger and thicker than those found on the 3 & Y. This is a significant requirement in handling the heavier and more powerful platform. Interestingly, Tesla chose not to implement a two-piece design. This results in a rather heavy rotor. A lot of thermal mass, but the lack of curved vanes inside the rotor means that the ability to shed heat is marginal for extended high speed driving.
Tesla Model S Plaid Front 400mm Big Brake Kit Caliper Rotor
Brake Fluid:​
At the time of writing, all Tesla’s come from the factory with DOT3 brake fluid – regardless of whether you have an SR+ Model 3 or a Plaid Model X! We recommend flushing the brake fluid every two years for a street-driven car. For aggressive street or track use (we cannot say this enough) – the brake fluid must be upgraded to a high-performance fluid such as Castrol SRF or Pagid RBF. Degraded brake fluid can boil in as little as ONE high-speed braking application on an extremely powerful car like a Palladium Model S. Even with high-quality fluid, once enough moisture is absorbed the boiling point drops drastically. That is why it is so critical to flush your brake fluid regularly if you’re planning on doing any kind of high-performance driving.
Concluding Thoughts:​
It is clear to see that there is a fair bit of carryover with Tesla’s braking system, as there is with many of their parts. Despite the legitimate claims against Tesla for using inadequate brake fluid and street-only pads, the factory caliper options are quite potent when paired with the correct fluid, pad, and rotor hardware upgrades!
Brake Fluid:​
I have a 3 long range, with MPP suspension, MC brace, fluid changed, and pads. I would be interesting in anything else that would enhance the feel. Used for spirited canyon driving.
I seems as though the rotational weight doesn't make any noticabe differance in performance. I do have forged wheels ordered.
Would the rotors make a noticeable difference, in braking feel and or a firmer pedal?
I'm searching for some quality replacement front rotors and pads. My searches included this thread. Nothing in the title indicates for current models only. What is a current model, anyway?
Sorry!
The Model S has gone through three significant visual iterations. The 2012-2015 "nose-cone", the 2016-2020 "refresh", and the 2021+ "Palladium" (current model).
The Palladium is a massive step forward in technology and reliability, building upon the Model 3/Y architecture. The previous gen Model S's were slowly upgraded over time, but a lot of the underlying hardware is/was pretty outdated.
If you have a (2015?) P85D, you should have Brembo 4-Piston Fixed calipers all-around with separate parking brakes. Tesla eventually moved to a floating, single-piston rear caliper with an integrated parking brake. Honestly, just go to Rock Auto, put in your car, and pick what is going to work best for you. They've generally got good selection and prices for OE replacement items. If replacing the rears, I'd recommend replacing the parking brake pads at the same time, since the calipers can be a bear to remove once rust/corrosion is present, so no point in doing it twice.
Found this thread by doing a research on brake upgrade options. After just ~10 hot laps on Model Y performance I've glazed the pads, boiled the brake fluid and warped left caliper. So +1000 to your comment that replacing brake fluid and pads is required for any track use.
Good news is that Tesla replaced the warped caliper under warranty no questions asked, and new caliper comes with pads already installed. But I'm not taking my Y to the road course until I upgrade the fluid and pads.
Reactions: hyp36rmax
Sounds like a good and safe plan! Pads and fluid should be the bare minimum if you know how to drive on a track.
FrontAP Racing (Red)Track Pack410 x 40mm One-Piece18.8 lbsForged 6-PistonModel S Plaid (20+ inch wheels)
RearAP Racing (Red)Track Pack410 x 32mm One-Piece13.8 lbsForged 4-PistonModel S Plaid (20+ inch wheels)
Brake Fluid:​
Just adding the track pack specs to the well organized table
Track Pack replaces the DOT3 with BASF Hydraulan 406 ESI DOT 4 fluid
Surface Transforms manufactures the rotors rather than AP Racing
Taken from the track pack thread:
