Interesting.Photos of a user who dismantled some elements of his TM3-P 2022 received last week show that:
- the 2 door tweeters are present (not activated)
- the 2 HP imaging medium (at the top of the door pillars) are present (not activated)
- in the center of the dashboard, the tweeter is missing which was parallel to the midrange loudspeaker (the midrange loudspeaker is present and works).
Still missing information related to the ECU connector map which most likely must have changed as Hansshow and evoffer indicate that the 2021 kits are not compatible with the 2022 Rysen.
Not at all ! In the LR/Performance there is moreFrom the posts above, is it looking like Tesla is including all the speakers from a "premium" system in the "non-premium" models?
Yes, the amplifier being integrated into the ECU, in the event of a problem Tesla can refuse to apply the warranty.Interesting.
Of course, it's probably one of those things where if you "activate" them, it will void the warranty, or something of the sort.
I'd be to check the fine prints of all the manuals, etc.
I’m thinking about doing the infinity 4032’s. Are they drop in? Or do I need some kind of spacers? If so, any links? TIAI put in the Infinity 4032 that have a tweeter integrated into the design. No need for the door/pillar tweeters in my view, and those also create the immersion effect that I dislike. I want a natural soundstage, not one like with headphones. My 2021 also had the center tweeter although I don't know if it is connected but I always assumed it was. I thought about disconnecting it when I did the Infinitys but decided not to and just left it. I also replaced the door woofers with the Focal ISU-200. I find it sounds better than the stock system in my SR+ but far from perfect. In any case I was blasting 60s hits today from Tidal. Lots of Zep, Beach Boys, Stones etc...
Would something like this be worth it? 2018 - 2021 Tesla Model 3 Powered BOOST Kit | PBK-TM3-VSW10S2
To apply your principle and have a natural sound scene (concert type) you have to leave only the front door speakers (woofer + tweeter).No need for the door/pillar tweeters in my view, and those also create the immersion effect that I dislike. I want a natural soundstage, not one like with headphones.
They need brackets that come from either Audioliphe.com or ampedgarage.com. They will also need a wire harness which both make as well. I used the AmpedGarage ones as they were available at that point in time. It isn't exactly a high volume business and they run small batches on a 3D printer.I’m thinking about doing the infinity 4032’s. Are they drop in? Or do I need some kind of spacers? If so, any links? TIA
Awesome picture! Could you elaborate more on what you mean by certain speakers “ are present , but not activated “ is that because of the removal of that center adjacent tweeter they removed ? Trying to get a sense of this new audio setup is even noticeable or if it sounds just as good if not potentially better then the past 14 plus one combo , Tesla claims the removal of that “ redundant “ tweeter proved no enhanced sound and allows for better audio down the line ! Curious your thoughts or what you or anyone has heard!! Thank you so muchPhotos of a user who dismantled some elements of his TM3-P 2022 received last week show that:
