I just bought a 14-30P to 14-50R EV Charger Adapter Cord, 30 AMP Dryer. Instead, can I buy the above cable to charge my car from Dryer out till I get garage unit installed?
It should work, assuming your dryer uses a 14-30 outlet (instead of 10-30).
Yes. I've done the same at AirBnB's.
I've had "OK" customer service with evseadapter. Returns and support have been "OK". I will still shop from them but cautiously.Also if any issue with fit, can I return cable back to evseadapter? If anyone has idea - thanks in advance for the help.
And THAT is the problem. Relying on memory to prevent you from burning your your house down is usually considered a bad idea.Yes. I've done the same at AirBnB's.
REMEMBER TO SET YOUR CURRENT/AMPERAGE TO 24A BEFORE YOU PLUG IT IN.
Current/amperage limit is saved on GPS coordinates. In theory, when coming back to the same GPS coordinates, it’ll use the custom current/amperage limit. But yes, I usually verify before plugging in at an Airbnb. It’s not too disruptive.And THAT is the problem. Relying on memory to prevent you from burning your your house down is usually considered a bad idea.
Or use the 14-50 cord. Adapt it down to 14-30 on the end and use 14-30 adapter. Heavier gauge is always a good thing. Still not recommended for long term use.Why not buy an extension cord for a 14-30 and then buy a Tesla 14-30 UMC adapter? The cord would be cheaper since the wires would not need to carry 50A, and the adapter would ensure you're only drawing 24A. The adapter may come in handy, or will at least be easy to sell to someone here.
Yeah my car isn’t suppose to auto lock at home based on GPS either. It was locking for a month. Now working again.Current/amperage limit is saved on GPS coordinates. In theory, when coming back to the same GPS coordinates, it’ll use the custom current/amperage limit. But yes, I usually verify before plugging in at an Airbnb. It’s not too disruptive.
Also, the extension cord is 6 AWG so it’s rated for 50A. The difference is that the neutral prong is chopped off to allow it be plugged into a dryer plug.Yeah my car isn’t suppose to auto lock at home based on GPS either. It was locking for a month. Now working again.
It’s not a good idea to depend on GPS as to if your house burns down or not. Yes it will will work 99.9% of the time. It’s that damn .1% that could cause serious harm.
The correct Adapter is not guaranteed to fault either but the odds of it pulling more current than it should are probably more like 0.000000001%
And depending on humans to verify it even Starts right every time is at best a failure rate of 1%
I get updates all the time that magically reset things and settings.
The new Gen 2 adaptor won't fit I think. I would need an small attachment for 14-30 for older cable. Does tesla sells those? Am I missing somethingWhy not buy an extension cord for a 14-30 and then buy a Tesla 14-30 UMC adapter? The cord would be cheaper since the wires would not need to carry 50A, and the adapter would ensure you're only drawing 24A. The adapter may come in handy, or will at least be easy to sell to someone here.
Yes, from all the reading I think I would have to set the Amp to 24. Hope I can do it thru Mobile App and also hoping car can remember setting itself to 24A when I charge at home.Yes. I've done the same at AirBnB's.
14-30 and 14-50 are "same" receptacle but the neutral is shaped different. Obviously, the current/amperage limits are different (30 vs 50). By chopping off the neutral prong on a NEMA 14-50, you can also use it for a 14-30. The 14-50 (50A) is 6 AWG. The lower the AWG, the bigger/heavier/inflexible it is, and the safer it is. So 6 AWG can be safely used for 50A as well as 30A.Look like I got Gen 1 mobile cable and would be good to have a extension to run from dryer to garage. It comes with 14-50 and regular out attachment:
Like: Tesla Model S 3 X Y OEM Mobile Charger Gen 1 240V 240 40amp NEMA 14-50 5-15 | eBay
I need suggestion, how to use Dryer outlet which is 14-30 with extension cable?
