@XHokie -- yes I found a great place, which coincidentally Tesla also uses when necessary for overflow work: Executive Tire, 750 E Gude Dr, Rockville, MD 20850, (301) 294-8820. They have more experience doing tire/wheel work on Teslas than anyone else with whom I spoke, including Designo. If you want to shop around in your area, be sure to verify whether a shop is being honest about its experience working on Teslas. The shop should be familiar with how to put the car in "Jack Mode," as well as Tesla's recommendation to manually tighten lug nuts instead of using an impact wrench. Almost everyone with whom I spoke failed one or both of these tests, except Executive Tire.
Are you planning to keep the OEM wheels for winter/summer use? If so, you will need to purchase a second set of TPMS sensors from Tesla ($200). The hard part is finding a shop to program them. Fortunately Executive Tire can do this, but very few others can.
Good luck!
