nwdiver
The diodes on a panel are in series with the solar cells. They prevent backflow current. A diode will only let current flow in one direction. This keeps shorts from happening in each panel. That's the ONLY thing a diode does.
The diagram below has one blocking diode, however each panel can have its own - which is common.
BYPASS Diode; not BLOCKING Diode...
If the cell group becomes reverse biased as happens when there's shade the diode becomes a short. Bypassing current around the shaded section. If this wasn't there shade can easily cause a fire. I learned this the hard way using panels without bypass diodes...
