Posting this problem that I am facing after installation for others to know and follow:
Having issues with Tesla Gateways resetting and power interuption.
Current system:
2 gateways, 4 powerwall, 24kw solar array
2 powerwalls are for Main House
2 powerwalls are for Guest Suite
Problem:
When the main house’s powerwalls and guest suite’s powerwalls are being charged by solar panels while connected to the grid; the 2 gateways glitches (house power goes off and then on) and reset themselves many times over the span of charging cycle. Glitch is noticeable because a momentary power outage occurs.
A) No it’s not power grid surges
B) Pattern is established and is reproduceable
C) Only happens when all the following conditions are true:
I put the guest suite's system on Off-Grid at night. Let the that part of the home run offgrid until the powerwalls are at 100%.
Current system:
Problem:
- Main House’s Powerwalls are under 100%
- Guest Suite’s Powerwalls are under 100%
- Main House’s Solar Panels are charging Powerwalls
- Guest Suite’s Solar Panel are charging Powerwalls
- Both system is On-Grid
