Navin
Would assume Elon is on his way to China. Maybe watching movies for the long plane ride. Any way to confirm that??
That preformed paletized base setup doesn't mean they are temporary. Nurburgring is similar and reportedly permanent.
Yeah, both only require underground feeds Being prewired from cabinet to pedestal saves time at install. Also might make shipping easier with less waste.
View attachment 465585 View attachment 465586
Edit: Split out two different points, one disagree and one agree.
Is it brush blowing into the lines that causes the problem? I had thought that the problem was downed lines, wherein the fact that our lines don't go down would be highly relevant (e.g.: make more durable power lines, since it clearly can be done). If the problem, contrarily, is brush blowing into the lines (that high up?), then our experience is not relevant.
The race is on. Will Tesla killers sell more EVs or will SpaceX launch more satellites ?SpaceX files application to launch 30 new satellites.
Harry Stoltz on Twitter
Wait, did I say "30"? I meant 30 thousand.
(Number of satellites currently in orbit: 1886)
Source: firefighter in the state of California
He’s blocked tracking so won’t see anything this wayDon’t know if its Elon but theres a G650 on the way back from Shanghai.
I posted a comparison of the Taycan with the MSP100D by a German Car TV Show Auto Mobil in the Taycan thread.
A positive highlight on the Supercharger network as compared with other options from Forbes:
In The U.S., Electric Vehicle Charging Prospects Are Bleak Out There (For The Rest Of Us Who Don’t Drive A Tesla Model 3)
Clever idea, alternating the direction of the flow through the battery pack with a valve, so that the warm (outlet) side of the coolant flow (e.g. where the cells are hottest) becomes the cool (inlet) side, and vice versa. And even if the valve "breaks" and gets stuck in one direction, your worst case scenario is... the current scenario.
Neat to see that they're looking to eliminate bandoliers / physical cooling channels entirely and going with pure free flow between cells. Although they also describe surrounding the cells with a phase-change material to hold the cells at a constant 30°C (takes energy to melt and melts at 30°C, so the temperature can't rise until it's fully melted). I'm not sure, after reading the patent, how the two concepts are supposed to work together.
Didn’t see this one here yet:
Tesla patent paves way for compact battery systems that are easier to produce
AGGREGATED BATTERY SYSTEM - Tesla, Inc.
My highlights in bold:
I recommend reading the entire patent. It seems pretty extensive and shows the value of vertical integration and might be tricky for competitors to copy.
The two most interesting things I read were:
- Phase change material that turns from solid to liquid to keep cells at optimal temp. PCM also turns to gas in case of thermal runaway and gas is expelled through dedicated vents away from other cells.
- Vague wording leaves the possibility of electrolyte not being confined inside individual cells. Possibly shared electrolyte throughout the module like a wet cell car battery. Patent only indicates the need to have a barrier between the electrolyte and the Dielectric cooling fluid. Would make assembly easier having to fill up the module with electrolyte instead of each cell.
Other stuff seems to be small tricks to simplify manufacturing and minimize parts by having parts perform multiple functions, (structural, electrical, cooling, assembly alignment).
Yeah, I found those electrolyte comments curious. I almost wonder if they're thinking about the possibility of replaceable electrolyte. Although that wouldn't remove degradation products from the cells. Drainable electrolytes would at least simplify recycling. You could also render a compromised pack inert by draining the electrolyte.
