powertoold
Play it at 0.25 speed to make it more realistic.
In that video it seems like Tesla used some HD maps?
Yes, this definitely felt to me like Elon was referring to raising capital.Something that most people missed. Oppenheimer asking the relevant question.
"Can you talk a little bit about what that look like, what your expectations are in terms of financing for the next 3 4 years to build up this fleet.
"blah blah cash flow neutral"
"We will make the right move. I think we will make the moves you think we should make."
So capital raise to build out the robotaxi fleet. Maybe end of 2020 is my prediction.
The last time I remember Elon saying everyone else was this wrong was HFC, and he was right. His reasoning against lidar made sense too. If you have cameras you don’t need lidar, and if you have lidar you still need cameras.
I wonder if the white car at 0:42 was our shorty friend trying to spoof it
Shorts will just compare it to the 2016 video and brush it off
I could be wrong, but increasingly I see other companies are not competent enough. They work on wrong strategy for years without realizing major problems.
If nothing else, shrink to 7nm or similar, which will reduce the per-unit cost. You will likely improve perf/W and possibly total performance (via clock speed increases) by doing so, but just making smaller devices will save you some money.Yea, so my question is what are the obvious improvements? And why, if 3.0 is sufficient ?
All three forward cameras are at the same height. They have different fields of view / zoom level (to have both a wide forward field of view and also be able to resolve objects in the distance). So naturally, the smaller FOV cameras will look more or less like cropped versions of the higher FOV cameras. But they're physically offset horizontally across a few cm so you could do stereo vision via the portion of the higher FOV that is shared with lower FOV, but you can also do depth perception with other techniques as described in the automation event, with a single camera.I knew there was a third low, but it appeared in that image set that two were the SAME from a view. Could be WA, downscaled to same. Both images looked the same, as well as a LOW view.
I'm on 2019.8.5 and the car will happily perform lane changes without touching the wheel - though eventually it will nag. Perhaps you just coincidentally have been getting nags at the same time as upcoming lane changes?No, there’s no hands on the wheel at all, even during lane changes...
EDIT: He updated and said it’s NoA... I think it must be some unreleased version. Current version I have requires hands on wheel before making a lane change.
Watched it at 1/4 speed and the only issue I noticed was a bit of shoulder around 1:36Oh shush
Edit: I actually have tears in my eyes. They effing did it. The autopilot screen has way more detail now too. Holy fud
Incorrect: there was a sliding with the calculation how much a robomile would cost, and Elon said that they would charge 1 dollar/mile. That’s all the analysts need to remember from todays presentation.
It's a Bimmer not Acura TLI wonder if the white car at 0:42 was our shorty friend trying to spoof it
The two obvious interpretations:Yes, this definitely felt to me like Elon was referring to raising capital.
Cool bicycle!
