bhtooefr
Three motors are the optimal engineering solution for a roadgoing sportscar. The Roadster2 accelerates at about 1.5 g from a standstill. Weight transfer during acceleration puts 2/3rds of the available traction on the rear axle, 1/3rd on the front. Three identical motors handles this situation perfectly.
A four motor design creates extra weight and/or complexity. Which means 3 motors beats 4 in a streetable car.
The Rimac is barely an engineering exercise, it's even in the name: "Concept One". Meanwhile, Tesla has already demonstrated torque vectoring with the Model 3 P "track mode". Software and OTA updates wins this race.
There's a few considerations here.
I'll start with the torque vectoring you mentioned.
AFAICT, the Model 3 uses a brake-based torque vectoring system - essentially, it uses the friction brake on the slipping wheel to load the (open) differential and send torque to the other side. This is extremely cheap (uses hardware you already have) and effective, and many automakers do it nowadays (up to and including McLaren).
However, while it's cheap and effective, it wears the brakes, and it obviously turns some of your forward momentum into heat, reducing performance and efficiency.
So, that's a reason to have two motors on an axle.
Now, as far as Rimac's implementation... well, they're not using four identical motors. The rear motors are larger and optimized for lower RPM (with a 2-speed gearbox to make up for that) in the Concept_One, although only slightly higher power rating. I don't have specs for the C_Two's individual motors, but I think your 1/3 to 2/3 split is actually pretty closely reflected in the available motor powers.
Does it add complexity (and more importantly for mass-market vehicles, cost) over a 3 motor system? Sure. But it adds performance over it, just as the 3-motor system will add performance and complexity over a 2-motor system using a small motor and a big motor (ala the Model S/X Performance).
