We're always telling people to use the bottom half of their battery during long trips and I thought a chart might help explain why.
I grabbed real data from a Supercharger session where I needed to charge close to 100%. This was for a 2017 X 100D. I subtracted from that curve a hypothetical charge curve that assumed the peak power (115 kW in this case) was maintained throughout the charge session. So as long as I'm charging at peak power there is no difference between the actual charge time and the "ideal" charge time, a zero on the chart.
Charging to 80%, for example, requires a little over 5 minutes more than if you could charge at peak power the entire time. That might be about the break even point between adding more energy at the current Supercharger or adding another Supercharger stop with an additional 5 minutes of overhead but faster charging at a lower charge level. I'd try to avoid charging above 80% just to be able to skip a Supercharger stop.
If you're charging to 100% during your trip when all you need is 60% to make it comfortably to the next Supercharger, you are wasting about 40 extra minutes by charging in the taper region instead of in the peak power region. That's not 40 minutes you'll make up later, it's just lost, unless you needed extra time for dinner or sleep.
I hope this chart makes it easy to see the time cost of charging above 80%.
