I'm thinking about adding a Model X from the 2016 through 2020 era to our Tesla fleet of one 2023 M3. Beside the usual focus on battery capacity, I have concerns about charging rates. Capacity is relatively easy to find in the original specs. Some dealers even list the current, fully charged range. However, charging rates are complex and not easy to come by.
We are really trying to determine if the older MX will charge fast enough on trip. We found in our half dozen or so trips that the M3 with Super Charging just about meets our charging needs: We stop for 15 - 30 minutes to get roughly 200 miles for our next hop. We like to drive at least 150 to 200 miles. It works.
From everything I've read, the 2016 - 2020 MX may not make our cut, but I'm still musing.
With the 2023 M3 as a standard, how much longer will the MX take to charge?
I was hoping to find more information comparing the current state of technology to the older MX line. eg if the current M3/Y capacilities allow a 20 minute stop on trips, how long would the older MX require? Specific questions:
1. Will the different models (70D, 90D, 100D) have different charging rates within the 20-80% SOC range?
2. What is that rate? My M3 rate is about 200 miles / 20 minutes
3. Within a model, does the charging rate improve significantly from 2016 to 2020?
Assumption is that the charger output is greater than the car's charging capacity. I'm assuming that the limitation is in the MX's cell chemistry, software and wire gauge.
Would appreciate any thoughts.
Thanks!
Gerry
Thanks!
Gerry
