67King
I did on the set I put on a Saturn SC2 over 20 years ago. God I'm old. I did not on the M3P. UP did not state, but they are progressive, and should get more firm as they compress. Now I don't know what the curves on the OEM springs versus UP are, but it is possible that if the rate is high enough that the car could hit the bump stop on an OEM spring in situations where it would not with an aftermarket spring, even if not trimmed. Given the risk that the dampers could bottom out, since I didn't remove springs, and put everyuthing through its full course, I left them alone. Figured if I were hitting the stops, I could go back and trim them, possibly without removing the assembly again. But if I HAD trimmed the, and did too much, I'd be looking at a damaged set of dampers, the inability to add back to the stop, and the certainty of the need to pull the assembly to install a new stop.
