Hello all,
I just purchased a used 2016 MS 60D with 12K miles and have a question about tire wear. I was unable to get any records so I don't know anything about service on the vehicle (e.g. did they do tire rotations) however a quick check of all the tires showed 2 at 7/32+ and 2 at just above 5/32. They are the OEM Goodyear Eagle Touring. I know on our FWD Volt, the fronts wear faster due to the fact the fronts do all work - regen, traction, braking, etc. What about on the AWD Teslas? Are the front more prone to tire wear? Or do the "D"s use rear wheel drive more? Trying to figure out how to 'rotate' the tires to get the most wear from them and hopefully balance out the wear before I have to replace them.
Thanks for all comments.
Frank
Michigan
Frank
Michigan
