I for my winter tires i run 255/40/20 on some 9" rims that are 30 offset. i know the stock rims are 8.5" and 40 offset for the front which is all I'm talking about because the rear tires are just fine.
When i backup and turn the front wheels rub on the inner fender but ONLY in reverse. Obviously this is because i have a different size than stock.
What i need help on is understanding offsets,
You can see on the screenshot from WTF its only a minimal difference in overall size so the issue is clearly the offset that makes it rub while turning in reverse. the first is with the current specs of my stock vs what i currently have, the second is if the aftermarket rims had a 40 offset instead of a 30
What are wheel spacers and can i install one that is equal to the 10 difference in my offset?
I have been using these for the last several years and they work amazing but that noise of the rubbing in reverse is just awful and turns heads in the wrong way and i want to correct it. I have already used a heat gun to mold the plastic a bit further away but its not enough.
