Anyone seen or used this dash cam before? It appears to be built custom for the model S. Super easy install.
Thoughts
yourwhip.com
Thoughts
yourwhip.com
That link is 404 for me.Anyone seen or used this dash cam before? It appears to be built custom for the model S. Super easy install.
yourwhip.com
I just bought one from Topfit through Amazon. Install was easy and custom design looks clean. The obvious problems I see is 1) all announciation from the camera upon powre up is in Chinese, and the manual is mostly in Chinese. Also the app is mostly in Chinese. Functionally, the wi-fi streaming of video from the camera is horrible! It's not close to being smooth even at low res of 720p. video stuck for 2-5 seconds before render frames for less than one second. Haven't manually copied out the videos from the micro SD card yet, and will try that later.
I read somewhere that you could change the language to English?
yes, you can do it. emailed to the seller, they will help you.I read somewhere that you could change the language to English?
it's said that Topfit has updated it, announciation can be changed into english. is it true?I just bought one from Topfit through Amazon. Install was easy and custom design looks clean. The obvious problems I see is 1) all announciation from the camera upon powre up is in Chinese, and the manual is mostly in Chinese. Also the app is mostly in Chinese. Functionally, the wi-fi streaming of video from the camera is horrible! It's not close to being smooth even at low res of 720p. video stuck for 2-5 seconds before render frames for less than one second. Haven't manually copied out the videos from the micro SD card yet, and will try that later.
yes, the topfit seller send me an attached file tell me how to change the Chinese language to English. They are very nice and helpful.I read somewhere that you could change the language to English?
I found Topfit have model s with 1.0 autopilot system dashcam, model X 1.0 and model X 2.0 dash cam on amazom. they are hot selling on amazon.Anyone seen or used this dash cam before? It appears to be built custom for the model S. Super easy install.
Thoughts
yourwhip.com
yes, you can ask the seller to get the update file, i did .it's said that Topfit has updated it, announciation can be changed into english. is it true?
