Tow Hitch Opening
So, I finally installed the tow hitch on my March 2017 MX. Anyway, now that the cover is gone, small animals or snakes could get in through the opening and build a nest. There's a nice little gap between battery and the bottom shield. It's rattle snake season in California and I'm a little worried. Just wondering how everyone feels about it and if anyone has any suggestions.
If I used it much, I would do the same. I wonder if you could order a spare cover and do some creative whittling :D to make one that would keep debris and critters out? I'm guessing Tesla assumes you will remove it all the time, but I can definitely see a case for never removing it, also. (I believe Bjorn never removes his, he uses it so much!)
Reactions: Kacey Green
I've asked about this. I guess I should remind my service center that I would like an extra to carve up. I leave my bike rack on all the time as I use it multiple times a week.
Looks like a good solution if you don't need access to the electrical connector. I just take mine off if I'm not using it, takes literally less than a minute to remove the towbar and replace the cover. I thought that was the whole point of a quick release! But obviously that doesn't help when it is in use if there are snakes and rodents about!
I do wonder why they made the access panel so large. Maybe gives service access to other things?
