I get that too...but at 41psiI am getting low pressure warning @ 44 PSI and cannot get rid of it.
Having had a long problem with TPMS I can tell you that on my car with V10, changing the wheel type from 21 to 19 and then driving a short distance and the "TPMS RESET" message will pop up. Switch back to the original wheels and repeat the process. Clunky but necessary if the car doesn't recognize the sensors. I had significant issues with a second set of wheels/tires (purchased from a reward receiver) and ultimately used Autel dual-frequency sensors programmed to "clone" the original wheels/tires (same serial numbers). Works perfectly now when switching from one set to the other.
