I've been seeing traction control kick in lately when taking freeway interchange ramps at speed (>60 mph), or taking cloverleaf type exits at >40mph. These are places where I never used to have any type of intervention, so something has changed.
First question....has anyone else seen more aggressive traction control intervention in scenarios like this after any of the software updates over the past couple of months?
The other possibility in my case is that I installed rear camber arms and front upper control arms back in March for additional camber at the track. I have had the rear at -2.0 degrees and front at -1.7 degrees for a few months. Recently changed the rear to -1.5 degrees and still seeing the same TC intervention. Toe has been checked and adjusted accordingly, currently sitting at 1/32" toe-in for the rear (about .05 degrees) and zero up front.
Only two things that have changed recently are software updates and alignment, so trying to figure out if others have seen increased TC aggressiveness, or if I need to keep playing with the camber on the street and set it closer to factory specs to prevent TC engagement in these scenarios where it's not necessary.
