Trip Planner range estimate with 22" wheels
FlatSix911
Porsche 918 Hybrid
Jun 15, 2015
6,473
5,884
Silicon Valley
How much does wheel weight factor in compared to wheel size? Many aftermarket 22"wheels advertise 40lbs savings over the factory 22" and depending upon tire selection you can save more (Conti extremecontact dws 06 weight 6lbs per tire less than the pirelli scorpion and 7 less than the Goodyear F1 asymmetric). So how much of a penalty would you pay with 22" that weigh less than even factory 20"?
It's definitely the weight that is the major factor here. Lighter is better for sure.
Bottom line ... lighter wheels are better for range :cool:
However, it is more complicated when you analyze the weight distribution within the wheel/tire assembly.
The rotational mass penalty is highest at the outer rim surface of the wheel and less at the center hub.
goneskiian
2,618
805
Bellevue WA
Yeah, you're talking to a bicycle racer. We're all about minimizing that rotational mass! I was trying to keep it simple. :rolleyes::p;)
InsaneDriver
233
49
Miami, FL
Interestingly enough, I doubt anyone publishes specific information around actual weight distribution of their wheels. However, the point that is clear, lighter tires will have more of an impact (or I can control it a little more with choose in tires) as that weight is the furthest from the center. Which is why I chose the Conti tires over the Pirelli or Goodyear, that 6-7lbs per tire is at the outer most critical area. Maybe good for a couple of extra miles.
Reactions: goneskiian
balefire
182
92
Chicago, IL
I'm not a bicycle racer but I compete in autocross where we change wheels for many reasons but primarily to gain time.
It's a lot more complicated than just weight.
The following affect range due to wheel and tire diameter size from 20" to 22":
Absolute weight of wheel.
Distribution of weight within wheel.
Low rolling resistance of tires.
Elasticity of wheel tire combo.
Aerodynamics of wheels.
When you increase the wheel diameter you worsen the rotational distribution of weight, pushing the tire weight to the outside, reducing range.
There are few 22in LRR tires (none last time I looked) and I bet the 20in LRR are more efficient than 22in LRR tires if they ever develop some. Lack of good LRR tires in 22 reduces range.
The elasticity of the wheel tire combo decreases when you upsize the wheel. This creates more energy loss and reduces range.
Finally the aerodynamics of the wheel affect range. Most aftermarket wheels are not designed for aerodynamics. I bet the OEM wheels have better aerodynamics. You will lose range when you upsize to aftermarket wheels due to aerodynamics.
The weight of the wheel is less an effect on the highway at constant speed. The weight of the wheel has more of an effect during acceleration and braking and cornering as wheel weight affects unsprung weight. In an autocross every lb saved on the wheel saves 0.1 sec on a 60 sec autocross course. If you extrapolate that to real life, that's not a lot of range unless you are driving in the city.
In contrast the aero wheels which I had on my old MS increased range by 3% and they were super heavy, almost 30 lbs each.
LRR tires used to be an option on my old MS and they were reported to gain 3% range too compared to regular tires.
Tesla had a link explaining all this on their website but I can't find it.
Conclusion. Buying lightweight bigger wheels will mitigate one of the above disadvantages but will not affect the other causes of reduced range. You will lose range. The price we pay for good looks.
The people on this and other threads that think there is no difference in range with bigger wheels are completely deluding themselves and relying on subjective data with recall bias instead of objective data
goneskiian
2,618
805
Bellevue WA
Great post!
I'm curious what percentage each change would make though. I would wager weight has the largest effect. Which seems to be the case with others getting lightweight 22" wheels and seeing a Wh/m decrease that is about equal to those with the 20" OEM offerings.
What do you think?
Cheers!
InsaneDriver
233
49
Miami, FL
I ordered some 22's I really like so when our X is delivered I plan on leaving the stock 20's on for a couple weeks and logging some trip data. Then I'll swap to the 22's and log the same trips ( knowing conditions won't be perfectly the same) and seeing what impact I get. Directional results will be fine with me because I really like the 22's that are coming.
ALLMYNE
199
72
Charlotte
Which 22's did you order?
