jmcclureXPA
I can answer your question with a direct, apples to apples personal experience. First, NO, you can not do 190 miles in "real world extreme conditions" with the heat on in the mountains driving 70 mph. I put 2,000 miles on a P100DL with 22" wheels in extreme weather in the mountains of Idaho and Montana. Considering the P100 should have slightly more range than your 90 (at least equal to) I can tell you there is virtually no chance of making it 190 miles in those conditions. You would have to drive 55-60mph and even then it's doubtful. I drove 140 miles losing 1,700' in elevation starting with a rated range of 270 miles (higher than a 100% charge on your 90) and arrived with 21 miles left. That means I used 249 rated miles to drive 140 miles downhill in extreme conditions. On the way home I was obviously climbing starting wth 267 miles of range. I had to stop and charge, no chance of making it the 140 miles.
My 90D with 20" wheels gets considerably better mileage. Last week I did the same drive only I started from home instead of the supercharger meaning the trip was 155 miles. I left with 260 miles rated range and arrived with 75 miles range. The temps were about 25 degrees warmer, but still below freezing. On the way home I left with 240 miles rated and arrived at the supercharger 140 miles away with 17 rated miles left.
In the P100DL with 22's I had to stop and supercharge three times between Salt Lake and home (450 miles) in my 90D with 20's I only had to charge twice, in very similar weather conditions.
I realize the performance motor draws a little more power, but I'd think the difference between the 90 battery and the 100 battery would more than make up for that. So the fact that my 90D gets substantially better mileage than the P100D I would have to attribute to the 20 vs. 22" wheels.
Thanks for the info! I appreciate the time and the real world conditions and your personal experience! Thanks again!!!
