trunk 12v outlet not working
3 days ago I added a new led light kit to the front and passenger areas using the 12v outlet in the center console.
I put my old led light strip in the trunk and it hasn't been working. I did test it on the center console and it does work.
I did a search and there's a fuse box on the driver side next to the go pedal. But does anyone know which fuse?
sorry, i pulled the panel and there was no fuse box. the video i looked at was actually for the X. i've looked through a bunch of install video and online searches, can't find anything on the Y fuse box...
X fuse box
no fuse box on the Y
i might have to put in a maint request on the app.
update. it was the cigarette lighter fuse (5 amp). the outlet works.
i plugged it into the center console and it wasn't working, so changed the fuse. it came on for a second and broke the fuse. put in a 3rd fuse and it worked. plugged it into the trunk outlet and its working.
Glad you found it. Where is the fuse? Hard to understand how a 5A fuse was the problem when the 12V (really 16V in current production cars) is rated for 12A continuous and 16A peak.
