Not true.
First of all we already had a higher high today like in the previous days which is very positive given the long $100 run up. Secondly momentum counts and although a set back would be justified we only see one direction these days and that is up. A lower level test would only be to confirm the run up anyway.
Last not least with every $ up we make more shorts nervous and some will decide to realizer losses rather than having another sleepless night. That will fuel the up movement even more.
Given the crazy high amount of shorts a squeeze cannot be ruled out but I believe its almost impossible to predict if at all and when. Situation of a squeeze is kind of complex.
IMO a continues up run is more healthy and stable too. A squeeze may turn a crazy jump and then we see it fall down to still higher levels but that would attract day traders and shorts as well as option trader again causing volatility.
This board has only be overoptimistic with some members predicting high jumps in a short timeframe.
So far looking at that what I call consensus here its been all happening and there is more to come.
Patience .... lean back and enjoy the show!
