Model S with 2170 by 19Q2 confirmed
Tesla and Panasonic have every incentive in the world to squeeze all the life that they can out of the capital they've sunk into 18650 production.
The easy way to improve range and charge rates (mph/kph) in Model S/X, at least excluding P100D, would be to swap one of the motors out for a PM motor. This will then be used for cruising and should up their average efficiency by 5-10%
Didn’t Elon and Deepak have a small chat about this on the last conference call. If I remember correctly Deepak said they were not battery constrained and Elon interjected, ‘well maybe for a week or so we were but not really.’
But now he’s saying that they are battery constrained apart from brief moments?
Don't confuse "We don't have enough cell supply to expand production" with "We don't have enough cell supply to maintain our current production rate". Also remember that this was specifically in reference to Model 3. Model 3 has been robbing cells from Tesla Energy for quite a while; Tesla Energy has been having to get by on the scraps and whatever cells they can secure from other manufacturers.
Panasonic never has a profit because they always need to reinvest... Tesla should simply buy the battery division from Panasonic.
I've said it before and I'll say it again: Tesla will turn on Panasonic whenever an opportunity presents itself (either an internal program that they think they can scale, or an outside company they could acquire; both options are mostly capital limited). Tesla is obsessed with vertical integration, both for retaining 100% of the profit, and for rapid turnaround without being constrained by outside entities, whose reliability may vary.
To me it just means Tesla is spending more on the Pick-Up than the Semi.
As Musk pointed out, there's a dfference between when something "comes out", and when it's "produced in volume"; the latter is what costs a lot of money. With many vehicles, but Semi in particular, Tesla needs to get them on the market, in some minimal volume, ASAP so that potential customers can experience them. With Semi, fleets will need time to trial the vehicles and decide whether they're saving money as they're supposed to. These small trial programs will then expand to large trial programs, which will then ultimately expand to phaseouts of existing diesel fleets. If barriers come up, Tesla will need to remedy these, which is yet another delay. So to reiterate, Tesla needs to get this process rolling ASAP.
"believed to be" ? But whatever it is, none of Tesla cars today can take 150 KW charging for more than a few minutes. Today it is barely sustaining 110 KW for more than say between 10 to 20% SoC.
Simply not true. Autocollected ABRP data for Model 3 LR:
Note the lack of data on the low end, so I wouldn't trust the shape of that upslope. But it's very clear that as a general rule, it's "just under 120kW" up to 50%, and deviations from this are the exception, not the rule. And indeed, Tesla has already stated that all of its current vehicles can take more than 120kW - only older vehicles cannot benefit from V3.
Also - side note: this is what the curve looks like
now. This should be Tesla's
conservative charge profile. But if Tesla later decides that cell longevity is meeting or exceeding conservative projections, they could well take a more aggressive charge profile with a future update.
What are Model 3's actual power limitations? It's hard to say. Factory mode and the EPA filings say 525A. Ingineerix has argued that the charge cabling is only good for 430A**. But both of these numbers are higher than V2's (350A?) limit.
** It's quite possible that both are correct. Cable nominal power ratings are generally for sustained usage - the current at which their rate of heat loss matches their rate of heat gain at their maximum safe temperature. But 5 minutes of high rate usage on a cool cable - getting them up to said temperature - followed by a rampdown - should be a perfectly acceptable alternative. I guess we'll find out. 525A is 50% more heating than 430A.
Doing some math... alumium has a specific heat of 0,9 J/g-C (Model 3's charge cabling is alumium, unlike S/X). 3-0 cable is 1,04cm in diameter, or a cross section of 0,85cm², with a mass of around 230g/m, or a heat capacity of around 207 J/m-C. Resistance should be around 0,00034 ohms/m. Heating is I²R, so ~93,7W/m, so 0,45°C temperature rise per second without accounting for passive cooling. I don't know the wire's class, but let's say that it's going from 25°C to 90°C. So without any passive cooling, it should take about 2 1/2 minutes to reach the maximum temperature. So yeah, with passive cooling, you should be able to run it at higher powers for maybe 3-6 minutes. I'm way too lasy to try to model the passive cooling to get a more precise figure than that
