There will be a next recession.
You can't run an economy faster than the available work supplied by human labor -- this changes as tech develops, but slowly. That is the *traditional* source of inflation, identified by the pre-Keynesian economists.
You can't run an economy faster than the food supply. That is the *ancient and medieval* (pre-economics) source of recessions. Climate change means this one will probably actually be coming up on us soon. Ugh.
You can't run an economy faster than the available *money* used to make deals happen. (Unless you go full command-and-control military-hierarchy, which usually has its own limitations due to failure to do price discovery). This is the source of recessions identified by *Keynes*, and the one which caused most of the recessions in the 19th and first half of the 20th century.
Yes, we go back to being labor constrained, or food constrained, or water constrained, or money constrained.
Edit: I'm loving the disagree on this. It's really no more than a list of axioms. Dying to see which axiom is disagreed with.
