Out of curiosity, what does one still utilize HAM for in this day and age?
To my Ham Radio friends. Power and Mounting Solution for Amateur Radio Dual Band VHF/UHF RigAnyone install a mobile radio (ham, commercial, or public safety) in a Model Y? I see some old posts for a Model 3 and Model S but nothing for a Y. Curious as to where you mounted the radio, control head, and antenna and where you got power.
How did you route through the moisture barrier? Is the cable just compressed by the rubber gasket?I just installed my dual-band antenna on my new Model Y. After much investigation I found that I can mount the antenna in two locations on the liftgate, either at the bottom near the tail lights of at the top side. I selected the area near the tail light so that my antenna would not hit the garage door. It may still hit the garage door when the door is open, though. I used black stick on wire pads from Lowes, see photos. I place three along the side of the liftgate plastic trim and one on the trunk. I'll use a 27.5" Diamond AZ507RSP 2m/70cm antenna. The rig will be placed under the trunk floor pad that's closest to the rear seat as there is enough room there. I'll get power from the 12V accessory socket at the inside left rear of the trunk. I need to locate where to mount the faceplate of the Yaesu FTM-6000R, looking at under the Tesla display.
