I've just had a Zappi Mk II fitted and when charging my M3 at a full 32A it typically shows a voltage (presumably at the Zappi unit itself) of about 227 volts whilst the car screen shows about 225 volts. Given the 6.5m of cable from the Zappi to the car, and metering error these are pretty consistent. I was a bit surprised by the figures given the Zappi is connected back to the consumer unit with 10mm cable and there is only 15m of it. My no-load supply voltage is normally almost spot on 240 volts (say plus or minus 1 volt). When I started chasing the voltage around I found that when the Zappi was running at 32A the voltage on my side of the electricity meter was only 230 volts. In other words the voltage drop from meter to Zappi was only 3 volts, but putting on a 32A load dropped the voltage at the meter from 240 to 230. Is this to be expected? The house is about 30 years old with an underground supply and 100amp main fuse. We are only about 300m from a big substation.
As a separate (but obviously related matter) do meters (ours is now a SMETS2 smart meter) record true watts - i.e. do they take account of voltage as well as current when calculating power used?
