Last night Astrape charged fine for the first hour and a half, then the charging limited to 24Amps and in the morning the charge was 25% short of target. The period when the drop changed looks like this in TeslaFi:
Dont worry about the weird at 12am thats when my night storage heaters kick in with 15kW of load. The Zappi charger has limited the house load to 100A because there was a water heater on at the same time. Thats all as it should be. The voltage spike is because the 7kW causes about 12V of voltage drop from network to house to car. So when the Zappi reduces the load the voltage seen by the car goes up. But at 12:36am the voltage dips to 211Volts and the amps clamps down to 24A. I presume this is the Tesla reacting to a low voltage point.
There is about 5V drop from the Zappi to the car, is that normal?
and about 4V drop from the grid incoming to the Zappi which is fine - 60 metres 16mm SWA. So the house incomer was about 220, which is within limits. The incomer drops about 0.5V per kW so without the 10V dropp caused by 20kW the unloaded grid voltage would be 230V. It was 237V at about 8pm this evening. Night time loads are heavy here as we have no local gas and 22 houses come off one small pole transformer. All of that seems perfectly normal for a UK supply. Is the car really supposed to restrict the amps at this fairly normal voltage? or is something else going on?
The Zappi was in FAST mode so no restriction there. I stopped the charge at the Zappi at 6:30 when I noticed this, and restarted it, and the car reverted to charging at 32 Amps.
Its super annoying to get up to a partly charged car when going out on a long work trip the next day. Any insights?
