Mainly out of curiosity, I'm trying to figure out someone the inner workings of the UMC. The UMC takes a signal from the NEMA adapter in the form of a resistance across the two small control pin in order to determine the max voltage/amperage the connecter can supply. It doesn't seem to me anyone has documented the specifics of For those of you with the various NEMA adapters and a simple multimeter, can you please unplug the connector from the UMC and measure the resistance across the 2 small lower center pins and post it here? Thanks.
