Hi,
My wife has 2019 MX dual motor… 22” staggered wheel setup… car has 22k miles… had oem tires swapped at the delivery in favor of all season conti DWSs that usually lasted 40-45k miles on the rest of the cars in the family.
Recently started getting low tire pressure on front right (passenger front) tire… looked to see if there is a nail and saw that the inner part of the tire was so worn out that I could see and feel the metal tire belts (first tire picture posted - after the alignment printout)… I checked out other 3 tires and all of them were unevenly worn out with left rear showing tire belts also.
I replaced all 4 tires immediately with Michelin Pilot all seasons 4s and took it for alignment… the strangest thing is that the tire that was worn out the most (right front) had the best alignment…
I understand that MX is heavier than most vehicles in its class and I could never rotate front/back due to staggered setup… plus all tires were unevenly worn out on the inside.
Any insight on why these tires lasted so little and alignment/tire wear observation?
