JPP
Just downloaded the latest version and tried again--I can log in OK now (maybe TM got things fixed, but still my Dashboard does not display). The app looks great--will need to explore. Many thanks.
There is another way to implement scheduled climate control, and it doesn't require any disclaimers or the app to run all the time. I don't know if command line switches are possible in Java, but if they are, then there could be one for turning on the climate control and another one for turning it off. A user could then use an external scheduling program to get the desired action. Actually even easier would be to just write two tiny programs "tesla_climate_on.exe" and "tesla_climate_off.exe" and run them as you want. Automatically turning on the climate control should probably only work if the car is plugged in.
Please note that there is a way to do this right now using the teslams package and the scheduler built into your computer's operating system. Here is an example for the mac of starting the charger at a certain time. It was created by hans.
For fans of jpasqua's work ... I made an icon that can be swapped for the java icon ... if you've done like I've done and put a shortcut on your desktop .....
Here http://www.7900novadrive.com/temp/tesla.zip
EDIT .. changed to .zip for ease of access.
NB. jpasqua has already added a useable icon of the FOB for this purpose with the latest drop ...
Thank you for the new version with the added parameter.
I'm sure this is going to be a duh moment for me but for the life of me I cannot find the file menu to export the data to CSV.
Is it on the graph tab?
It's in the File menu as shown below. Let me know if it's not showing up for you. This is version 0.19.02.
I didn't realize that the MenuBar was not displaying on Windows! I thought it was set up properly to use whatever menubar is appropriate for the system (as it does on the Mac) but apparently I need to do something different on Windows. I'll get it sorted out later this week.
@MichaelS: If you'd be willing I will send you a test version when I think I have it fixed.
teslams already let's you run a simple command to start charging, turn on the AC, etc. The example linked to above seems kind of technical, but there are GUI tools that will let you plug in these sorts of commands in a simple manner on both Windows and Mac. This could also be done without any special program. It could simply be a batch file (shell script) with the appropriate curl commands.
Thanks for the pointer. I just downloaded it and looked it over. Once my car arrives I will build a new version of teslams that exits immediately if the car is not attached to a charger. I will use this new version when playing with scheduled tasks using the Windows Task Scheduler.
Can the windows be opened or closed ?
I made a visit to a supercharger today to record the results. The voltage does read out DC volts when connected to a supercharger. So the volts is actually input voltage. AC current stays 0 during supercharging. All the other values read back as expected.
