Some additional info if Im allowed.
The modern spare is 145/85R18 103M stands 27.7" tall
The Vredestein is 195/75R18 106P stands 29.5" tall
OEM 19 is 255/45R19 104W stands 28" tall
When compared to the oem 19"
Modern spare size difference .3"
Vredestein differences 1.5"
Based off standard information that can be found on spares, This is typically ok for short distances, as long as the tire is with in 2 inches.
Additionally the Center bore size is 67.1 on the Vredestein and 64.1 on the model y, a hub ring is suggested.
According to Maserati dealer in Arizona these are interchangeable on all models of the Levante, have the same load rating, and that the new steel rim version supersedes the 5 spoke. I messed around an ordered a tire in the middle of the night, and had to deal with getting it canceled because it was wrong. In short do your own research and assume the risk associated with it.
This is the same pump the Maserati comes with, Also for what its worth the Ghibili jack is a pin jack, which looking at it you might be able to use that to lift the car and not use jack pads.inflated the tire with the Tesla pump (took about 6-8 minutes, IIRC) mounted it, both back and front. Perfect fitment. I left it on the right front, drove 10 miles, residential, up to 50mph, lots of harsh concrete, listening for anomalies. Zero noticeable issues.
The car drove and felt totally normal. I even have photos showing that the stance of the car looked totally normal. The inflated tire is very close to full-size OEM. The tread width is about 7", vs. the Modern Spare.
This is what I have found take it for what its worth. The Model Y/3 bolt pattern is 114.3x5. There are two types of spares for the Levante, one with a 5 spoke aluminum rim and one with a steel rim. The tires mounted to both are 195/75R18 106P, be careful not to get the 95P version.As with any mod, YMMV! If you choose to go to the trouble of LOCATING one of these wheels/tires off a wrecked Maserati Levante, that's your choice. All of the risk is on you. (Jeez, I guess I've hung out with enough lawyers, and "Karen"s that I felt the need to say this!!!)
There are TWO different Vredestein SpaceMaster sizes for Maserati. AFAIK, the Ghibli spare does NOT fit (different lug bolt dimensions). As for part numbers, I'm not going to post them here, as there was some confusion between what the Maserati dealer told me vs. what Parts_Link told me, so it's up to y'all to find the right wheel/tire. The wheel/tire I purchased fits, that's all I can confirm.
